things showing yellow
33 REPLIES 33
Message 1 of 34
tessilly85
2134 Views, 33 Replies
how do I make things not show up yellow. Anytime I put up architecture families or generic families up they come up yellow.
33 REPLIES 33
Message 21 of 34
mhiserZFHXS
in reply to: tessilly85
You never acknowledged if my comment worked or not. In the early images, when told to open the type properties of the elements, you opened the type properties of the view. Select the elements, and then "edit type". I am almost certain those are just the materials you or someone else assigned to these.
Message 22 of 34
tessilly85
@mhiserZFHXS
Message 23 of 34
tessilly85
Message 24 of 34
mhiserZFHXS
Open up the GWB material.
Message 25 of 34
tessilly85
in reply to: mhiserZFHXS
Message 26 of 34
tessilly85
Message 27 of 34
mhiserZFHXS
Go to the Graphics tab.
Message 28 of 34
mhiserZFHXS
Okay, you checked the view template before. Did you check the Visibility/Graphics Overrides?
Message 29 of 34
tessilly85
Message 30 of 34
tessilly85
It's just in the floor plan. and if you take the view template off it doesn't change
Message 31 of 34
tessilly85
Message 32 of 34
tessilly85
Message 33 of 34
Can't you just share the model?  Strip out any top-secret information that you don't want to fall into the wrong hands?
Message 34 of 34
tessilly85
in reply to: barthbradley
I deleted the floor plans and whatever it was, was associated with that. Thank you though. It kind of drives me nuts to not know but I need to move on. thank you both so much. And no this is the strictest privacy place I have worked at by far.
Forma Design Contest
