The common line between stair and floor
6 REPLIES 6
m.pharamawy
303 Views, 6 Replies
why cant i remove this line between stairs and floor while i already joined them both .
is there another solution rather than covering it with masks or regions
noting that both have the same material.
6 REPLIES 6
in reply to: m.pharamawy
Stairs don't join with floors or anything else. You have to use Linework tool to change the adjoining lines to invisible.
m.pharamawy
in reply to: ToanDN
when i searched for a solution i found some one suggested to put a landing for the stair which may help to join the floor. do u think it may help ?
A landing is still a part of the stair and it won't join with anything. It just makes you move the joint from one location to another.
that will just move the problem...... ;-(
m.pharamawy
in reply to: ToanDN
Additionally it cannot contain layers like floor. right ?
i believe your first solution is more logic
thanks dear
m.pharamawy
i am having another question if u please can help, i'll appreciate that very much
https://forums.autodesk.com/t5/revit-architecture-forum/i-am-trying-to-add-concrete-head-to-openings...
Forma Design Contest
