as per attached screen shots, i am trying to add a concrete bar over the opening inside the wall, so far I've succeeded to do what i want except one only problem, i hope u can help me with it.
the concrete bar hatch should replace the brick wall hatch, or hide it. but as shown both are appearing, i tried to add mask region in the family of the window but it hided both the wall hatch and my bar. i tried also to edit the visibility of the bar and nothing helps.
and please do not suggest to use the filled region in the view because i have to make it globally not per item or view
thanks a lot in advance
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Can edit the window family so as to provide a lintel ("concrete head") to your opening.
Nevertheless i would go for ToanDN solution it's simpler.
Regards, Dan
