Texts can't be selected on region area
6 REPLIES 6
fangirlinga5
439 Views, 6 Replies
Hello!
I have a problem with Revit, this happens to every element on the surface of a region area.
I am trying to select the text below (highlighted in a red box), but I cannot select itwhen it's on the surface of a masked region. I can't edit/move/copy etc. the texts.
This problem did not occur before, I do not know if I unselected something.
Thank you in advance.
6 REPLIES 6
blank...
in reply to: fangirlinga5
Hover over text and press tab doesn't work?
fangirlinga5
in reply to: blank...
It works! Thank you very much!
Moreover, is there a way to do this without having to click tab? It's my first time experiencing this as this didn't happen before.
blank...
Not that I know, as far as I know it's always been like that. Maybe one of us is misremembering.
fangirlinga5
I see, I just updated my Revit maybe what I am saying is just on the older version.
Thank you so much and bless you!
Check options to control element selection.  Maybe disabling "by face" will duplicate the behavior you experienced in the past.
Help | Options to Control Element Selection | Autodesk
fangirlinga5
IT WORKS! Thank you! I might have unknowingly selected it.
Forma Design Contest
Technology Administrators
