Sweep Along Ramp
Sweep Along Ramp
aguajardoVSZGD
Sweep Along Ramp
aguajardoVSZGD
Working on a project with a lot of moulding. I am needing a sweep to follow along a ramp. I am having trouble figuring this one out.
TasnimTarannum
I don't think there is any such option that directly allow sweeping along a ramp. I would do that with Model in-place.
Use Railing.
Corsten.Au
Hello
@ToanDN  As Toan mentioned, use railing, ( custom profile ), so that it can follow the ramp.
I usually use ramp, copied further up and then edit the profile in case of curbs ( kerbs )..
In Place sweep can work , use the ramp edge as a guide.
have a look.
Ramp, copied further up and edit profile.Ramp, copied further up and edit profile.you can pick and edit the edge , when you are in pick path it will show  the point to drag along..you can pick and edit the edge , when you are in pick path it will show the point to drag along..In Place sweep using ramp edge... you can customise the profile..In Place sweep using ramp edge... you can customise the profile..
Corsten
Building Designer
aguajardoVSZGD
Thank you! I will give this a try
aguajardoVSZGD
I got it to work by selecting the edge of the ramp, thank you for your help @Corsten.Au !
