Design Options in Revit
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
jose.deleon32FDJ
275 Aufrufe, 1 Antwort
  1. How to remove an element from a design option set to the main model?
  2. How to move an element to another design option set?
Thanks in advance
Beschriftungen (1)
1 ANTWORT 1
Nachricht 2 von 2
SteveKStafford
als Antwort auf: jose.deleon32FDJ
Once elements are assigned to a Design Option use either Cut to Clipboard (move to Main Model or another option) or Copy to Clipboard (add to another design option). Then use Paste Aligned to place it while the other Design Option is being edited or the Main Model is active.
If an element isn't assigned to any Design Option then using the Add to Option tool is ideal.
Steve Stafford
