Announcements
Adjusting CAD site plan shape to surface of toposolid
ZenState
ZenState
I got site map for project which is elevated according to 1 meter contour lines but then I have created a toposolid in Revit from more precise 3D model of terrain and I was wondering if there is some way to adjust it to the new model so it could be viewed in 3D with site map laying on surface of toposolid and make it more comprehensible. Because now the lines of the map are always switching from below and above the surface and make it pretty confusing.
Thank you for any suggestions.
Corsten.Au
Hello
You may use modify Sub Elements to fix the toposolid.
Picking points which required adjusting, and type in the required elevation.
Corsten
Building Designer
ZenState
Thanks, but I'd need to adjust the line map a leave the toposurface as it is. Besides it is larger area and even this would take impossible amount of time.
