Working on a project with a lot of moulding. I am needing a sweep to follow along a ramp. I am having trouble figuring this one out.
Solved by Corsten.Au. Go to Solution.
Hello
@ToanDN As Toan mentioned, use railing, ( custom profile ), so that it can follow the ramp.
I usually use ramp, copied further up and then edit the profile in case of curbs ( kerbs )..
In Place sweep can work , use the ramp edge as a guide.
have a look.
I got it to work by selecting the edge of the ramp, thank you for your help @Corsten.Au !
