stuck in "modify" mode
Message 1 of 22
I'm currently in a drawing in Revit 2012 and can not exit "modify: mode.  The ribbon does not display the checkmark or "X" to exit. I've cycled through different ribbons but can't exit.
Donald
Replies (21)
Message 2 of 22
arunag
See that your Revit 2012 is up to date with service pack2 and also has the hotfix
Aruna
School of Architecture
Ramaiah Institute of Technology
Bangalore
Message 3 of 22
Thanks,  I'll look to see where to find service packs.
Donald
Message 4 of 22
The communication center states that my software is up to date, any other suggests?  The problem only occurs in one project file.
I appreciate the assistance.
Message 5 of 22
David_W_Koch
That hotfix can be found here:
http://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/hotfix-autodes...
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 6 of 22
Thanks, that was easy enough, still stuck in the mode in the one file fthough, I'll try going back a couple backups to see if I can get out.
much apprciate the information.
Message 7 of 22
I'm still stuck in modify mode, is there a key command that I can use to "accept" the change?
Message 8 of 22
I may be good now thanks for your help
Message 9 of 22
having a similiar problem in edit mode, with revit 2015, esc or modiydoes not cancel the action or let me out, have to save and close and reopen, anyone have afix?
Michael
Donald
Message 10 of 22
Michael
Message 11 of 22
This happens to me about once in awhile in revit 2015.  If it is a central model, I've been able to get out of the edit mode by trying the "synchronize now" button.  An error appears that synchronization isn't allow when you are in edit mode, then like magic the X and checkmark options come back to close the edit session.
Message 12 of 22
Just experienced this as well when trying to copy/monitor from a linked file.  The synchronize now option was unavailable, but I was able to use the undo arrows at the top ribbon to exit out of the edit mode.
Message 13 of 22
Or you can assign a keyboard shortcut to the command and type it in to finish it when you are stuck in Edit mode.
Message 14 of 22
save the project and it will save it as it was before u entered into the editing. once saved the finish tick and cross re appear
Message 15 of 22
aaj157
"FG" did the trick!
Message 16 of 22
the only comment that actually helps.  thanks.
Message 17 of 22
jasonmccool8686
Undo was the only thing out of all the suggestions that worked for me when experiencing a similar problem in steel plate edit mode in Revit 2022. Thanks for mentioning that!
Message 18 of 22
leoniegorman
Community Visitor
Community Visitor
The undo arrows worked for me! Thank you!
Message 19 of 22
sarveshQV295
this worked for me.
Message 20 of 22
ms_sepulveda
Community Visitor
Community Visitor
This was the most helpful! I have this issue in v2024.
