structure or Architecture Floor Layer not Exported in IFC file.
HiTεsH
HiTεsH
Dear Team,
I am working on one of the Road project in Revit 2019. In this project, I have the base aggregate in the road with 3 different layer. In revit we had created 1 floor geometry with 3 different layer in it. This floor is in slope with different elevations and in curved as well. Another issue is we cant create a 3 different floor for different layer because we need to cut the floor at the  both edge for natural slop for the road
End Goal: Export the IFC with different layer of road.
we have tried below option but goal is not achieved.
 1) Tried to create a Part in the revit but this option is inactive. since the floor is in slop with different elevation & in curved shape. (Refer Attached Image-1). we have tried below solution but issue not resolve.(https://forums.autodesk.com/t5/revit-architecture-forum/ifc-export-structural-core-layers-only/td-p/...)
2) Exported IFC with inbuilt IFC export setup but the result of the export is 1 floor without a layer in it. (Image-2)
do we have any solution for this case? i want the IFC floor with different layer. Please share the best possible solution for this case.
 @ToanDN , Please help me out this issue for the project progress.
XXalessio.amodioXX
You can try to split the floor in parts and see if it works
@HiTεsH wrote:
Dear Team,
It appears you do need to create 3 floors.  I don't understand the statement why you can't quoted above.
@HiTεsH
If you can be using Revit 2022 then you can create parts from sloped floors or floors with edited sub-elements.
HiTεsH
okay thanks for the helping....
and happy to hear about this feature has added in revit 2022
RDAOU
@HiTεsH
Nothing changed in 2022...
Multi Layered floors with modified sub-elements cannot be converted to parts in any version...It works exactly the same as previous versions Floors with modified sub-elements can be converted to parts ONLY if the Floor element consists of ONE/SINGLE layer (SEE GIF 1) .
That being said, you do NOT NEED to use multiple floor elements. You can use 1 Floor element consisting of 1 Layer/Material >>> Modify its sub elements >>> Convert it to Parts >>> Divide Parts and set material >> Export to IFC (SEE GIF 2)
GIF 1
GIF 2
If you prefer to use multiple floor elements you would need to only split the variable layer and model that as a separate floor element ie: If the built-up section contains 9 layers and only the top is variable you would need only 2 floor element not 10... 1 single + 1 with 8 layers (convert both to parts)
