IFC Export - Structural Core Layers Only?
1 ANTWORT 1
Nachricht 1 von 2
dbrainard
1574 Aufrufe, 1 Antwort
Hello, I'm attempting to export an .IFC file from Revit where only the Structural Core layers for my Walls, Floors and Roofs come through - No Finish Layers (Coverings). So far, I have attempted to manipulate the IFC Export Options by using the "Not Exported" value for IFC Class / Type Name on the Finish 1, Finish 2, Membrane and Substrate sub-layers. I am currently using the BIM Vision viewer to validate the export results and it still seems to be producing the overall mass of the wall with sub-layer information. Is what I'm trying to accomplish do-able and if so, what is the best approach for doing so? Thank You!
Working in Revit 2019 at present.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: dbrainard
You have to create parts from walls/floors/roofs, then exclude non-structural layers from the parts, change the 3d view to Show parts, and export to IFC with the Options: Export visible elements in view only and Export parts as building elements.
