Some problem with Angle Control
agnija.praskelevica
Message 1 of 15
agnija.praskelevica
Hello!
I have a problem with angle control.
There you can see my light with two lighting fixtures - light console and light head.
I need to change my horizontal angle that my light console "walk" tangent to light head, like that, and that is automatic:
But now, if I change my angle, my light console is like that: (I already tried to align my two Lighting Fixtures)
Can anyone help with that? 🙂 (2 days already searched information about that)
Thank you!
Agnija
Replies (14)
Message 2 of 15
kadmonkee
try adjusting the location of rotation axis
504 measures from a center point of a reference line associated to the part of the light fixture that actually rotates.
assign and lock a reference line from the axis point to the center  of the light fixture that needs to rotate along that axis line (reference line)
it should work the same as a door swing angle
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 3 of 15
Is the element that you are trying to rotate a nested family hosted to a Ref. Line?
Just post the RFA here and let us see how it is constructed.
Message 4 of 15
agnija.praskelevica
No it's hosted to a ref. plane.
Message 5 of 15
Yeah, your family isn't constructed correctly.  It's fixable though. I just need to know how it is suppose to flex. Can you provide a picture of the actual light fixture - or a Link to the Manufacturer's website? Looks like it is a wall- mounted light fixture that tilts up and down, while that "bracket" remains in a stationary position attached to the wall.  Something like I'm showing here without the bracket:
Message 6 of 15
agnija.praskelevica
This light is like street lantern and light source "head" is in a stationary position parallel to ground, but only the second part of light tilts up and down, like that:
Message 7 of 15
You sure about that?
Isn't a streetlight mounted on a stationary pole and the fixture aimed at the street?
Message 8 of 15
agnija.praskelevica
I am pretty sure about that, but maybe I am wrong.
Nevertheless, now my only problem is angle rotation point.
I need, that my rotation takes place around this point (in this file).
Message 9 of 15
agnija.praskelevica
Yes! You are right!
I solved my problem, but I have a another problem and I see, that You know that! 🙂
How do you join light source and light "head'' together? Becauce Revit don't let me change the light source angle.
Message 10 of 15
Hopefully, you can reverse-engineer the attached Family to see how it's done. Basically, your Light Fixture Family is Nested into another Family and Hosted to a Ref. Line Work Plane that has an adjustable angle.
NOTE: Light Fixture Family is "Work Plane-Based" and not "Always Vertical" and "Shared".
NOTE: Since Light Fixture Family is "Shared", you can directly access and change it's properties by TAB-Selecting on the Light Fixture in either the Hosting Family or in the Project.
NOTE: Ref. Line (Work Plane) was placed in Elevation View and its TIP was LOCKED at the X and Y Origin Ref. Planes -- and then the  Angular Dimension was pulled and Labeled.
Good luck.
Message 11 of 15
RDAOU
🙂 a solution fiesta or what is this exactly?
Message 12 of 15
HEY! I'm playing at this table. Don't jinx it. I'm about to split a pair of eights.
Message 13 of 15
agnija.praskelevica
Haha! 😄
Because all soloutions were almost right and something worked, something not. (except mine)
Sorry about solution spam. 😄 My foult!
Message 14 of 15
agnija.praskelevica
This solution is working! Thank you!
You are awesome!
Message 15 of 15
agnija.praskelevica
I can not open your file, because I have a revit 2021, but I understand your solution.
