Message 1 of 13
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I loaded in a structural column family so that I could include the capitals in the model. I replaced my architectural columns with these.
When I removed the architectural columns, the boolean cuts I made to the floor disappeared, so I changed the floor to a structural floor and then the column/floor interaction automatically looked like this:
I don't seem to be able to manually cut/join the two structural elements.
I eventually have to add thickened slab edges around the columns, as well as around the perimeter of the slab at the bearing walls.
So how do I fix the graphics to appear like the condition with the architectural column:
Thanks for your thoughts and assistance.
Revit is amazing
