Structural columns and cutting floors
cbt990
Message 1 of 13
cbt990
I loaded in a structural column family so that I could include the capitals in the model. I replaced my architectural columns with these.
When I removed the architectural columns, the boolean cuts I made to the floor disappeared, so I changed the floor to a structural floor and then the column/floor interaction automatically looked like this:
I don't seem to be able to manually cut/join the two structural elements.
I eventually have to add thickened slab edges around the columns, as well as around the perimeter of the slab at the bearing walls.
So how do I fix the graphics to appear like the condition with the architectural column:
Thanks for your thoughts and assistance.
Revit is amazing
Replies (12)
Message 2 of 13
I am holding on answer this because you have the tendency of finding out your own solutions within 5 minutes of posting the questions 😉
Message 3 of 13
Make the Medium or Fine Geometry visible in Coarse View in the Family. Then you can Join to Floor in Project.
Message 4 of 13
cbt990
so it seems like it is accurate that an architectural floor cannot be cut by a structural column?
Is it also correct that I can't cut structural floors with a structural column? it seems to not be working
Revit is amazing
Message 5 of 13
Did you do what I suggested?
Message 6 of 13
You need to use Join Geometry, not Cut geometry.  Then switch the join order accordingly.
Message 7 of 13
cbt990
I think it was already set up that way.
Revit is amazing
Message 8 of 13
cbt990
Joining: floor then column:
Column then floor:
Revit is amazing
Message 9 of 13
Column then floor:
Use the actual Switch Join Order tool.
Message 10 of 13
Looks like it Joins, but in the incorrect order. Switch Join Order.
Message 11 of 13
cbt990
Great, thank you.
Revit is amazing
Message 12 of 13
cbt990
Is this a better workflow generally for showing slab/structural interactions than splitting the slab into multiple floors at the edge of all the walls which divide them?
Revit is amazing
Message 13 of 13
Join geometry.  If the slab stops at the walls then switch join order.
