Strange Visibility issues in 3d view - seeing through walls
3 REPLIES 3
robinG3P9Q
277 Views, 3 Replies
Hi all,
I have what I'm hoping is an easy fix, but I came in to work today and in the 3d view I am seeing elements through walls and other strange things like that. I've attached a picture which should hopefully explain the issue much better than I can through words. What is going on here? What can I do to fix it? Things were displaying just fine on Friday. What other information can I provide to help figure this out? Please let me know and I will be happy to elaborate.
Thank you very much!
3 REPLIES 3
in reply to: robinG3P9Q
- Delete the view and create a new 3D view from the Home button
- If that still doesn't fix, turn off CAD imports
Kev_D
@robinG3P9Q It could be a graphic issue. Uncheck Hardware Acceleration (File > Options) and restart Revit.
ennujozlagam
check in the properties if there is assigned view template and set to none.
Forma Design Contest
