Hi all,
I have what I'm hoping is an easy fix, but I came in to work today and in the 3d view I am seeing elements through walls and other strange things like that. I've attached a picture which should hopefully explain the issue much better than I can through words. What is going on here? What can I do to fix it? Things were displaying just fine on Friday. What other information can I provide to help figure this out? Please let me know and I will be happy to elaborate.
Thank you very much!
- Delete the view and create a new 3D view from the Home button
- If that still doesn't fix, turn off CAD imports
@robinG3P9Q It could be a graphic issue. Uncheck Hardware Acceleration (File > Options) and restart Revit.
check in the properties if there is assigned view template and set to none.
