Hi all
Does an STL exporter exist for Revit 2019? Upgraded from 2018 and the plugin worked great for that version but doesn't work for the 2019 version, any ideas? Thank in advance.
Solved by Viveka_CD. Go to Solution.
Hi @Anonymous
I just heard back from the dedicated resource.
The STL exporter has been published via the Autodesk Desktop App and Autodesk Accounts.
Let me know if you download and install the app.
STL exporter for Revit 2019
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
I still can not find the 2019 version. Also, I did the chat with the help desk and he said it does not exist yet. He sent me the link to the 2017 version and I installed it, but it does not show up under the Plug-Ins tab in Revit. Please, could you link a download that will work with Revit 2019?
Hi @Anonymous
I see that you are a new visitor. Welcome to the Autodesk community!
This maybe related to an account issue. Please Contact Autodesk Support and we can have a specialist look into your account information.
Meanwhile, can you try a reinstall of the desktop app, sign out and sign it back again and make sure you have Revit 2019 open? Let me know if this helps resolve your issue.
Viveka CD
I also cannot locate the add in. Your help chat with a "product expert" seems to think its standard with Revit 2019 (its not). Can you provide a link to this program?
@bgpollard did you happen to look for this update in your Desktop App?
Viveka CD
Today I have also checked in :
Revit 2019 > Updates & Add-ons
and the STL Exporter is still not present.
Can you please provide a direct link to the EXE/MSI?
James
What kind of subscription account do you have?
Viveka CD
If you have an educational account, you may not have access to domains that provide the updates in their account.
Another thing is to check for a secure internet connection and check on a different browser.
You can contact the educational support team - they have a form to fill out. Please see HERE
I have to check back with the team if I can directly share the MSI installation file with you.
Let me know if you have any questions.
Viveka CD
As an Educational Institution, I have an Education account and will put in a request via the link you gave.
Thank you.
Sounds good! Let me know if you got help on this issue.
I'll check back in a few days.
Viveka CD
Hi Viveka
I have been having some issues for a while now, think some time early last year, where I cannot see updates for my Revit 2019 on the Desktop App, and via my Autodesk Account. I only get the updates up till 2018 Products. Could you kindly assist with this.
where can I find a link to download and install the Revit 2019 STL exporter?
I've looked in my AutoDesk account, All Products and Services and in Product Updates, but still cannot see a download.
Chris
Product Updates... If you don't see any updates you may not have the permission by your account administrator to see product updates.
STL exporter is not available via any app, after multiple failed attempts to get in touch with help team still cannot locate the STL exporter add-on. Please express interest over this issue.
Sorry for disturbing I´m having the same problem. I can´t find STL EXPORTER 2019 in Autodesk Accounts or Desktop app. Could you please help me. Thanks in advance!
Hello, my apologies for disturbing. I cannot find STL Exporter 2019 en Autodesk Accounts neither Desktop apps, could you please help me to find it? Thanks in advance!
Hi Augustin,
I found it here: https://manage.autodesk.com/cep/#products-services/updates
Which is the Autodesk Account page > All Products and Services > Updates and then search/find on the page 'STL'.
Kind regards,
James
