Hi all
Does an STL exporter exist for Revit 2019? Upgraded from 2018 and the plugin worked great for that version but doesn't work for the 2019 version, any ideas? Thank in advance.
Solved by Viveka_CD. Go to Solution.
Hi, James!
First of all, thank you for answering. I,ve found a 2018 revit version inside the link you posted. I'm using 2019 version. Is it ok for this revit version? I downloaded STL exporter and installed it but nothing happen. Should I follow any other step in order to activate this plug in?
Hi Agustin,
I believe you do have to use the correct version. Once installed, you will find the STL Exporter for Revit icon under the Add-Ins menu, as in this picture.
Kind regards,
James
