Design Options Error
1 ANTWORT 1
Nachricht 1 von 2
357 Aufrufe, 1 Antwort
Hello all,
I've been working with design options on a project and this error comes up when I try to move a curtain wall system to a set. The whole wall is selected in the view including the wall, mullions, inserts grids etc. and this error appears. For some reason the wall can be moved to a secondary design option but not to a primary. Is there a reason for this?
The alternative would be to make the secondary to primary when I'm happy with the contents of the set. I'm wondering if I'm missing a step here or if there is a valid reason for items not being able to be moved to a primary set?
Thank you.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
Use Clipboard Cut & Paste Aligned to Same Place to move elements between Design Options or back to the Main Model.
