I have no issues with brick and mortar buildings, but the dreaded day that I have to do my first steel structure building has come.
General question about truss creation:
This is what we get from the structural engineer. It's very specific and detailed, so in the family template I created that exact truss, with those exact dimensions and then stretch it to that exact dimension in the project. Since it doesn't have to be parametric. Everything looks fine, Is this an OK approach for such cases or did I broke some Revit truss rule that will give me headaches down the road?
Specific question 1:
When I use the notch tool, looking in 3D it does the job correctly, but in elevation I get this line. How do I get rid of it, I don't see any graphical options in notch parameters.
Specific question 2:
How to notch multiple elements, as in these examples. I can get there by drawing reference planes that follow bottom chords and then extend one web, cut, extend another, cut, draw reference planes that follow the webs, extend the middle one, cut, cut again... Is this it, or is there a faster automatic way?
Specific question 3:
Is there some direct way to get the actual weight of the elements, in kg?
Again, I did come up with a way, outside of Revit convert unit weight from kN/m3 to kg/m3, then calculate how much that is since I can schedule material volume. I presume some custom parameters and calculated fields could do it in Revit, but that's too much hassle in this case, Excel is easier. Did I miss a field somewhere to get to kilograms directly in Revit?
Specific question 4:
What is the proper way of creating custom elements? Cyan element that sits on top of the column in this image. I just pick a template and model it? I though I'd start with the column itself and modify it, so I can keep structural analysis parameters, so I can get the weight of them. Is this an OK approach for such cases or did I broke some Revit rule that will give me headaches down the road?
Specific question 5:
Connections, they can be placed only one at a time. For example column base plates, I can't select all of the columns and place base plates on all of them. Is it OK to place one and array / copy it to others, or did I broke some Revit rule that will give me headaches down the road?
Thanks in advance!
Thanks @barthbradley
Anyone has any info on other questions, am I on the right track?
This is an oversight with steel connection. You would need to use Linework tool to clean up the line.
Maybe ask this question over Revit Structure forum.
https://forums.autodesk.com/t5/revit-structure-forum/bd-p/153
You can add a Calculated Value parameter:
You can create families and choosing a proper template:
If it is truly unique element, you can create it using in-place model and choosing a proper category.
You can copy-multiple a connection. I don't think array will work though.
Thanks in advance!
