Stairs
18 REPLIES 18
Message 1 of 19
zs-17
632 Views, 18 Replies
Stairs
I'm sketching U shape stairs as 2 straight runs in addition to 1 arc shape run, the construction concrete is available only below the last run only. How to fix this problem.
TStairs 01.jpgStairs.jpghanks
18 REPLIES 18
Message 2 of 19
in reply to: zs-17
Stair by Sketch.
Message 3 of 19
in reply to: zs-17
Actually, I don't understand what you are asking. And your screenshot is too dark.  Hard to tell what you are calling out.  What to try again?
Message 4 of 19
zs-17
in reply to: barthbradley
Hi, I created stairs by sketch. The stairs made of construction concrete with treads and risers. The red arrow indicates that only the last part of the stairs has construction concrete when the other parts have only treads and risers. The problem is that there is no concrete when all these 3 parts of the stairs have the same properties and it's not related to a particular view or camera.
Thank you for your support.
Message 5 of 19
in reply to: zs-17
Increase the Structural Depth.
....this:
Message 6 of 19
zs-17
The structural depth increases the thickness of the available concrete. But it will not add concrete to the missing one
Message 7 of 19
in reply to: zs-17
HUH?  I still don't understand your issue. Post the file.
Message 8 of 19
zs-17
It's a stair without concrete
Message 9 of 19
zs-17
Message 10 of 19
in reply to: zs-17
Turn off Riser.
Message 11 of 19
zs-17
in reply to: ToanDN
Turn it off will show the concrete. But if I switch it on again the concrete disappears. In the end, I should turn it on for a material purpose.
Message 12 of 19
in reply to: zs-17
It's FUBAR.  It should work with both Risers and Treads.  Just re-do it.
BTW: Yours works fine if I change the Riser Thickness. Go figure.
Message 13 of 19
in reply to: zs-17
Keep Riser on and change Nosing Length to at least equal to Riser thickness.
Message 14 of 19
zs-17
The riser thickness has no effect on my file. I will redo it later on and see if I can get a better result.
Many thanks
Message 15 of 19
in reply to: zs-17
Just tried @ToanDN's suggestion. Works like a charm.
Message 16 of 19
zs-17
in reply to: ToanDN
Yes this works
Best Regrads
Message 17 of 19
in reply to: zs-17
FWIW: Looks like you discovered a bone fide limitation.  This is a totally replicable phenom. Weird. But fun when you find 'em.  Now we need to find a workaround.  I mean, nosing is not acceptible to me personally.
Message 18 of 19
BTW @zs-17 : I think you meant to give @ToanDN a lil' green check mark. Not two of them to me.  I appreciate the one though.  Thx. They're fun to get.
Message 19 of 19
zs-17
I accepted both solutions. You both tried to help. It's very cheerful to find a solution.
Forma Design Contest
