Hi all,
I was wondering if anyone has any idea on how I could flip the stair rail handle so that its facing the right way? It seems to be mounting to the wall correctly but the handle is facing the opposite way.
Solved by RDAOU. Go to Solution.
Tab select the Hand rail and use the Flip Arrows
Actually, I think flip will reverse the support as well. Instead, Edit Rail and reverse the arrow by tapping on it.
Hi thank you for your help. I tried both your suggestions, flipping it with the arrow and going into editing mode too but the handle remains the same in both cases
How did you make the handrail? Is the wall return an extension, termination, or part of the handrail path?
Seems to work fine here...Ways may differ depending on how you have set it up...IF the flip arrows wont work at your end, try the following
Option 1:
Option 2:
Alternatively, you can do the following too
You can always attach the rail to a post and someone can have a look at it
