Stair Rail
6 REPLIES 6
parkside125
520 Views, 6 Replies
Stair Rail
Hi all,
I was wondering if anyone has any idea on how I could flip the stair rail handle so that its facing the right way? It seems to be mounting to the wall correctly but the handle is facing the opposite way.
Tags (3)
Labels (3)
6 REPLIES 6
RDAOU
in reply to: parkside125
@parkside125
Tab select the Hand rail and use the Flip Arrows
Actually, I think flip will reverse the support as well.  Instead, Edit Rail and reverse the arrow by tapping on it.
parkside125
in reply to: RDAOU
Thanks for your suggestion. When I flip it, the mounting flips but the handle still remains in the same place.
parkside125
in reply to: barthbradley
Hi thank you for your help. I tried both your suggestions, flipping it with the arrow and going into editing mode too but the handle remains the same in both cases
Lachlan-JWP
How did you make the handrail? Is the wall return an extension, termination, or part of the handrail path?
RDAOU
@parkside125
Seems to work fine here...Ways may differ depending on how you have set it up...IF the flip arrows wont work at your end, try the following
Option 1:
  1. Edit Rail
  2. Change position of the handrail Right/Left
Option 2:
Alternatively, you can do the following too
  1. select the wall supports (Hover cursor over and use TAB to select)
  2. Right Click
  3. select Flip Support
You can always attach the rail to a post and someone can have a look at it
