Curve waterproofing line.
2 ANTWORTEN 2
Nachricht 1 von 3
Darwin33
510 Aufrufe, 2 Antworten
I have in my families a straight line for waterprofing membrane ( fill not fill rectangules) , my question is if I can curve that line with an specific radio, or do I have to draw a curved line again
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Darwin33
If you family is a straight line then you can only draw straight lines.  Can you use a line type instead?
Nachricht 3 von 3
RDAOU
@Darwin33
A straight line is a straight line it cannot bend...Assuming that you are using a line based detail item, you can add a type to the family (1/2 Circle & 1/4 Circle)
If they are non-standard curves then it would be easier to add them using Detail Lines directly in the model...I am assuming that is what ToanD meant by using a line type
