Space Frame for Heydar Aliyev Centre like structure
10 REPLIES 10
Message 1 of 11
sgalloway1
1335 Views, 10 Replies
As part of summer learning I'm trying to replicate a structure similar to the Heydar Aliyev Centre. As part of this, I have learnt how to do a space frame structure by using a curtain panel pattern family which works wonderfully, however it looks malformed. Despite numerous attempts at changing the number on the u and v grid it still malforms.
Furthermore, how would it be best to close the gap between the windows and the the structure so there isn't a hole.
Would appreciate your help,
Sam.
Labels (4)
10 REPLIES 10
Message 2 of 11
in reply to: sgalloway1
Your Panel Family is not constrained -- or built -- properly.  Try flexing it.
Message 3 of 11
Here's a fun looking one:
You know, it's all about hosting Ref. Points to Work Planes of other Ref. Points that "drive" the hosted Ref. Point. It's a symbiotic relationship you are striving for, and it's dependent on Parameters (mostly to control the RP's OFFSET from its Host).
Message 4 of 11
I don't think a curtain panel pattern based will work here. Here is what I would do:
- Create a form for of the entire roof space frame
- Divide both the top and the bottom surfaces of the form and match the UV of the two divided surfaces
- Create an adaptive generic model with 8 adaptive points to form a space frame module, create a member though each pair of points to create the space frame model (or load in a shared 2-point adaptive family and host it to each pair of points)
- Load this module family to the conceptual mass and pick 8 points (4 from the top surface and 4 from the bottom surface) to place one module.
- Use Repeater tool to populate the one module to the entire mass form
Message 5 of 11
See if this helps...
Message 6 of 11
Here's a revised file that includes the "roofing" portion on the panel.  It threw on error on loading, but Revit was able to correct it. I don't want to track it down right now. Maybe you can find the source.  Overall it looks good to me. You be the judge.
Message 7 of 11
sgalloway1
in reply to: barthbradley
@barthbradley
This works wonderfully. Thanks very much for your help 🙂
Message 8 of 11
@sgalloway1 wrote:
@barthbradley
Great! Is it worthy of a solution credit?
Message 9 of 11
Hey @sgalloway1! If a Solution Credit is out of the question, then how about signing this "Certificate of Award" for me instead?
...oh! and date it too please.
Message 10 of 11
sgalloway1
@barthbradley  would you rather me sign the certificate so you can put it in the what I'm sure is a huge collection?
Message 11 of 11
Horse walks into a bar and asks the bartender for a beer. Bartender serves the horse and asks  "Why the long face, buddy?"
What do you think, Samuel?  Do you think I can give up my day job and make it as a comedian? Let me know.
Forma Design Contest
Technology Administrators
