"The following render appearance images are missing ...
2 ANTWORTEN 2
Nachricht 1 von 3
324 Aufrufe, 2 Antworten
I am facing a problem in Autodesk Revit 2019 . Whenever i try to render my model with sky cloudy very cloudy any type of cloud it gives the following error i tried to check the options render path but i couldn't find render library in my program data revit folder or anywhere else. I have attached a screen shot so that you can understand the problem kindly help me solve this issue. Thank you.Error screen shot.jpg
2 ANTWORTEN 2
Nachricht 2 von 3
syman2000
als Antwort auf: Anonymous
I would grab one of the texture from online and replace the missing texture. Here is a sample I got from google search.
Nachricht 3 von 3
ennujozlagam
you can refer to this article and see if helps. thanks
