Space borders not printing
4 REPLIES 4
Prvoime
188 Views, 4 Replies
I need a volume diagram of a building, with hatched plan views and sections. Done with spaces, but space borders don't print in sections.
Tried moving color scheme from background to foreground, didn't help.
Tried applying a view filter forcing space borders to be black, didn't help.
Any solution aside from manually adding detail lines? File attached.
4 REPLIES 4
in reply to: Prvoime
What about using Grid Lines for that?
...you asked about dimensioning in your other thread, so it seems this approach would also provide a smart way to do that.  Food for thought.
Lance.Coffey
@Prvoime To add a bit clarity around this behavior, I've found that the Space elements border is coming from the Space's Interior subcategory (you can see this as the border disappears when turning off the Interior subcategory in the view), and based on what I'm seeing for Rooms, this is not supposed/expected to be printed.
As a result, another workflow (like the one @barthbradley mentioned) would need to be used.
Lance Coffey
Technical Support Specialist
Prvoime
So I didn't miss a checkbox somewhere. Thanks everyone!
Forma Design Contest
Technology Administrators
