Design option vs Phases for documentation
8 REPLIES 8
Message 1 of 9
Carlos.Mozqueda_FK
290 Views, 8 Replies
I have two small towers which will be built in two different stages, Building A will be built in the next 2 years while Building B will be built in the next 5 years. Both towers will be connected by a small bridge.
Currently, I am using phases for each stage. Phase 01 contains Building A while Phase 02 contains Building B. The issue I am having is that with the current documentation we are showing both stages together and therefore the rooms on stage 1 are not visible in stage 2.
The solutions I was considering are;
- Copy rooms from stage 01 to stage 02 and keep using phases.
- Use a design option and place all building B in a design option. In this way, I won't have any duplicate rooms.
Any ideas of a better workflow or issues that can happen with each way of solving this issue?
8 REPLIES 8
Message 2 of 9
rxi.gg
in reply to: Carlos.Mozqueda_FK
I think I would go with your first option.
I always avoid using design options as they are very annoying to use.
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Message 3 of 9
Phase Filters and Graphic Overrides should get you there.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-con...
Message 4 of 9
rxi.gg
in reply to: barthbradley
if i'm not wrong, it is not possible to use phase filters in schedules
Message 5 of 9
Not sure if I follow. So you want to see everything in one view? Why not just turn off phase filter (set to None)?
Message 6 of 9
vancikv
in reply to: rxi.gg
At least in 2021 it's possible.
Message 7 of 9
rxi.gg
in reply to: vancikv
In room schedules the phase filter parameter disappears.
Message 8 of 9
rxi.gg
Not in one view, if im not wrong, he want all rooms (both phases) in one schedule
Message 9 of 9
I would keep using phases.  Copy rooms from one stage to another is okay.  But if you don't want to do it, create a view with only rooms and tags of the future stage, overlay it on sheet with the view of the current stage.
Forma Design Contest
Technology Administrators
