North arrow rotational parameter
6 REPLIES 6
yes_and_no
287 Views, 6 Replies
Guys, I can lock the north arrow line into a reference plane, but have it rotate about the center seems very tricky. How do you lock that endpoint to the circle center yet allow it to rotate nicely as angular parameter ?
6 REPLIES 6
in reply to: yes_and_no
- Create a Symbol family
- Nest it in the North Arrow family, host it on a reference line
- Create an angular parameter to rotate the reference line
Why don't you just insert the North Arrow Symbol into a TRUE NORTH View?  It will then point to True North when View is changed to Project North.
You can also have a true compass.
Prvoime
in reply to: ToanDN
Is this a custom family?
in reply to: Prvoime
View.
Prvoime
in reply to: barthbradley
@barthbradley
Oh, right, sun path, missing sun path threw me off. If anyone stumbles on this, you have to set solar study to "Lighting" to get rid of the sun path, can't have just the compass with other options.
Forma Design Contest
