Why does my floor framing system only show as dashed line?
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
svalente9GJKH
337 Aufrufe, 4 Antworten
I tried to create a floor beam system with 2x10s and when I hover over it, they just show as dashed lines.
How can I get the 2x10 to show?
4 ANTWORTEN 4
Nachricht 2 von 5
cbt990
als Antwort auf: svalente9GJKH
Adjust view coarseness to medium or higher.
Revit is amazing
Nachricht 3 von 5
Change the Detail Level to Medium or Fine and drop the View Range.
Nachricht 4 von 5
- Structural Framing category must be visible
- Detail Level =  Medium or Fine to show true beam; Detail Level  = Coarse to show stick symbol (single line)
- Beams are within the view range
Nachricht 5 von 5
rxi.gg
Can you upload the model as we can check it?
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
