Hello, I am trying to create a model with slanted walls and curtain walls. Using only the wall command, I can't succeed. Do I have to use 'In Place Mass'?
But also with 'In Place Mass', I get rough edges (see pictures).only walls
try with in place mass
rough edge
thx for any help
Stefan
Try to pick your curtain wall if you see blue dot stretch that blue dot to innner face of the wall , then select the dot right click in your mouse and select wall not joint (cannot remember the exact word) and see if helps. Thanks
Neat trick. If it's true.
Looks - and sounds - like you created a slanted Wall Type without the use of a Mass and without modeling the Wall In-Place.
Frankly, I don't buy into it.
So, are you going to tell us how did you did it?
