Slanted walls & curtain walls
3 REPLIES 3
cad.sl
265 Views, 3 Replies
Hello, I am trying to create a model with slanted walls and curtain walls. Using only the wall command, I can't succeed. Do I have to use 'In Place Mass'?
But also with 'In Place Mass', I get rough edges (see pictures).only wallsonly wallstry with in place masstry with in place massrough edgerough edge
thx for any help
Stefan
3 REPLIES 3
ennujozlagam
in reply to: cad.sl
Try to pick your curtain wall if you see blue dot stretch that blue dot to innner face of the wall , then select the dot right click in your mouse and select wall not joint (cannot remember the exact word) and see if helps. Thanks
in reply to: cad.sl
Create an in place mass of the entire form and wall by face all around so that they clean up nicely. Then you can hide the walls that you don't need.
in reply to: cad.sl
Neat trick. If it's true.
Looks - and sounds - like you  created a slanted Wall Type without the use of a Mass and without modeling the Wall In-Place.
Frankly, I don't buy into it.
So, are you going to tell us how did you did it?
Forma Design Contest
Technology Administrators
