sketchy view lines in 3d view
4 REPLIES 4
xu.teng
2319 Views, 4 Replies
can someone tell me what's wrong with my graphic option in 3d view. it shows sketchy edge lines.
4 REPLIES 4
in reply to: xu.teng
Delete the view and create a new 3D view see if you can still see them.
xu.teng
in reply to: ToanDN
thank you, it solves the problem, is this revit bug issue.
3D views can get corrupted after a lot of zooming and orbiting.
I have experienced a similar phemon on occasion.  I don't know how it's caused, but I do know how to correct it.  End session and close Revit. Update Display Adapter Driver through Device Manager. Re-launch Revit and voila!  Problem solved.
...but, sometimes the 3D view is just corrupted. **it happens.
Forma Design Contest
