Link Autocad file to revit
20 ANTWORTEN 20
GELÖST
Nachricht 1 von 21
1839 Aufrufe, 20 Antworten
Hello friends, I have a frustrating error each time I am trying to link a cad file to Revit. Even though I am doing all these things
delete frozen layers
move to 0,0,0
explode attributes
explode
flatten
purge
audit
quick select change z to 0
20 ANTWORTEN 20
Nachricht 2 von 21
syman2000
als Antwort auf: Anonymous
In AutoCAD you can try WBLOCK command and select the part of the drawings you want to save. Another method I try is use ERASE command and press A for ALL. Before I press enter, I would press R for REMOVE. Select the part you want to remove from selection and then press ENTER to delete part of outside of your drawing object.
Also if your drawing contain blocks that has huge insert point distance, it will trigger Revit to say you have object that is 33KM away.
Nachricht 3 von 21
als Antwort auf: syman2000
I already did that, but still no good news
Nachricht 4 von 21
syman2000
Post a sample file and we will diagnose.
Nachricht 5 von 21
How can I attach AutoCAD file here?
Nachricht 6 von 21
syman2000
Scroll down the reply post and you will see there is an attachment button
Nachricht 7 von 21
Thank You
Nachricht 8 von 21
syman2000
I notice there are text and hatches that has huge elevation difference. So I use the old -CH (CHANGE) command and set the elevation to 0. I kept the points elevation as is incase you want to create topo from the points.
Nachricht 9 von 21
Thank you for help, I changed the height of texts and hatches to 0, but still have that problem.
Nachricht 10 von 21
syman2000
I've attached the fixed file so you can use it. If you want to fixed it manually, you need to go to AutoCAD 3d view to see what other objects are away from the elevation.
Nachricht 11 von 21
I get these kind of errors all the time.  Never had an issue resolving. Usually, just moving the CAD to where it is suppose to be in the Revit Project if enough.   Or, re-linking Center to Center and then re-positioning  CAD in the Revit Project.
Nachricht 12 von 21
Must have missed something....as I moved everything that was like -267845.959 + to 0 from a 3D view except for the points above at the 100+/- level and saved.  I then tried to link back into Revit and I didn't get any error messages bringing it in origin to origin.
And....now I have to update my template as my origin location is incorrect.
Nachricht 13 von 21
What are you saying @Anonymous ???  Sounds like you are saying the Link messed with Revit's Internal Origin. I must be misunderstanding.
Nachricht 14 von 21
Do you want a quick fix without messing with the CAD file?  Link it in a plan view with box Current View only ticked.  That's it.
Furthermore, you can export that view back to DWG and you will have a CAD file completely flat.  Now you can link it in Revit again without having to tick the box mentioned above so that you can see it in any views including 3d.
Nachricht 15 von 21
als Antwort auf: ToanDN
Didn't work for me.
1. Link CAD to Plan View. Current View Only checked.
2. Export CAD to dwg.
3.  Delete CAD in Revit
4. Go to 3D View and Link CAD. Current View unchecked.
Nachricht 16 von 21
als Antwort auf: barthbradley
Nope...bringing it in by origin it wasn't where I had it specified in my template, or someone else messed with my template and moved my grids.  I double checked with my own origin dwg file.
Nachricht 17 von 21
Didn't work for me.
Works here.
Nachricht 18 von 21
I did but didn't work, still had the same error
Nachricht 19 von 21
Did you see the files I attached?
- Start a new Revit project, not your working file, Link or Import the CAD file in a floor plan origin to origin, with the Current View Only checked
- Export the plan view to DWG with a new name; you can close the Revit file after export without saving
- Open your working Revit file, open an non-cropped floor plan view, Link the new DWG in, origin to origin, with the Current View Only box Unchecked
It should work.
https://knowledge.autodesk.com/community/screencast/c9f6323a-e117-4f19-8738-06b2c27a62f0
Nachricht 20 von 21
Yes, but mine didn't work :enttäuschtes_Gesicht:
