Site floor plan
8 REPLIES 8
Message 1 of 9
beyhanbayhan
3178 Views, 8 Replies
Site floor plan
hello,
i can not see site floor plan. How can i fix it.
thenk you.
Tags (2)
8 REPLIES 8
Message 2 of 9
kadmonkee
in reply to: beyhanbayhan
does it show up in a floor plan, section or elevation?
check "VG" visibility graphics for categories turned off
confirm nothing is in temporary hide mode
is it imported from AutoCAD?
what is your crop region set to?
turn on your section box and adjust the size of that it could be it is cropped out.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 3 of 9
beyhanbayhan
+ floor plans
    level 1
    level 2
    level 3
    site (i can not  not see)  🙂
Message 4 of 9
kadmonkee
in the view that you can NOT see it check the "VG" settings for SITE and IMPORT Categories
what does the site contain?
Linked files or actual Revit content?
look into the circled area from the image if things are NOT CHECKED you will NOT see them
thank you
Message 5 of 9
beyhanbayhan
in reply to: kadmonkee
i try to make your suggestions, bu it does not happens. i has revit content and  i can see all of them. i have to can draw site plan in autocad but site button has't. thank you your halp 🙂
Message 6 of 9
Site plan is just a Name. If you don't have a specific Site Level then duplicate the level 1 floor plan and rename it to Site plan.
Message 7 of 9
beyhanbayhan
in reply to: ToanDN
ok. how can i make site floor plan wiew settings.
thank you.
Message 8 of 9
Depends. Do you want to see the roof or the footprint of the building?
If the roof, change the view range's Top to Unlimited, Cut plane to above the highest point of the building, Bottom to Level 1, View depth to Unlimited.
Message 9 of 9
beyhanbayhan
in reply to: ToanDN
thank you so much.
Forma Design Contest
