does it show up in a floor plan, section or elevation?
check "VG" visibility graphics for categories turned off
confirm nothing is in temporary hide mode
is it imported from AutoCAD?
what is your crop region set to?
turn on your section box and adjust the size of that it could be it is cropped out.
in the view that you can NOT see it check the "VG" settings for SITE and IMPORT Categories
what does the site contain?
Linked files or actual Revit content?
look into the circled area from the image if things are NOT CHECKED you will NOT see them
i try to make your suggestions, bu it does not happens. i has revit content and i can see all of them. i have to can draw site plan in autocad but site button has't. thank you your halp 🙂
