Shedual
11 REPLIES 11
Message 1 of 12
sabamail65
393 Views, 11 Replies
Shedual
How can I create a table like the submitted form so that it separates different drawings, for example, separate structural drawings and separate architectural drawings?
11 REPLIES 11
Message 2 of 12
RDAOU
in reply to: sabamail65
@sabamail65
Add an instance project parameter to Sheets category (Drawing Discipline) then Sort and group Sheets and Schedule/sheet list using that parameter
Message 3 of 12
sabamail65
Thank you dear RDAOU
Message 4 of 12
sabamail65
in reply to: RDAOU
Sorry I had another question. How can I arrange the table to my liking? For example, first be public, then architecture, then structure, and so on
Message 5 of 12
RDAOU
The sorting works alphanumerically ...
Either add the order sequence to the initial sorting parameter you used above ... something like 00.Gerneral 01.Architectural 02.Structural
OR add a new project parameter to sheet Category like below
Message 6 of 12
sabamail65
Thank you RDAOU
Message 7 of 12
sabamail65
Hi RDAOU. Hello. Why is the order of the architectural part disturbed?
Message 8 of 12
RDAOU
@sabamail65
Go to Sorting and Grouping and from the drop down menu of the  third criteria ... Select "Sheet Number"
Now you should have
  1. Sheet Discipline (Hidden - Shown in Header)
  2. Discipline Grouping (Hidden)
  3. Sheet Number
Message 9 of 12
sabamail65
Message 10 of 12
sabamail65
Hello RDAOU . I have a plan in the form of a submitted photo. But I do not know how to show the walls as shown in the photo. Without creating walls of different thicknesses.
Message 11 of 12
RDAOU
@sabamail65
Hi...this is a new topic not related to Scheduling. How about you start a new thread/post with a specific subject and we can discuss there
Clarify also the source of that image...is a pdf a DWG ...
Message 12 of 12
sabamail65
in reply to: RDAOU
Sure
Forma Design Contest
Technology Administrators
