Screen issues
Screen issues
When I execute Revit 16, it doesn't run like it should because I watch this revit bug 1.png
And, for example, when i want to build a wall, the green command ribbon doesn't allow me to enter datas.revit bug 2.png
L.Maas
Is this a fresh install or is this a sudden occurence? Which operating sytem are you using?
At least make sure that you have the latest updates (Revit, Windows, Graphics card)
Louis
Please mention Revit version, especially when uploading Revit files.
It's a fresh install and I use Windows 8.1 64bits.
My system is updated.
I noticed that if I connect my laptop to a screen, there is no problem. So if think it could come from the size of my screen's laptop but I don't know how to fix it.
RDAOU
Hello @Anonymous
You can try one of the following
  1. go to Windows Control Panel > Display and set it to 125% or 150%
  2. Depending on the model/type of Graphic card you have you can control/adjust screen resolution via the Graphic Card Control Panel which should be located in the task bar (lower right corner)
