When I execute Revit 16, it doesn't run like it should because I watch this
And, for example, when i want to build a wall, the green command ribbon doesn't allow me to enter datas.
Solved by RDAOU. Go to Solution.
Is this a fresh install or is this a sudden occurence? Which operating sytem are you using?
At least make sure that you have the latest updates (Revit, Windows, Graphics card)
Louis
Please mention Revit version, especially when uploading Revit files.
It's a fresh install and I use Windows 8.1 64bits.
My system is updated.
I noticed that if I connect my laptop to a screen, there is no problem. So if think it could come from the size of my screen's laptop but I don't know how to fix it.
Hello @Anonymous
You can try one of the following
