Can't make curved curtain wall
4 REPLIES 4
11673 Views, 4 Replies
I cannot make a curved curtain wall. Curtain walls drawn with an arc come up straight (generic walls can be made in an arc). I have tried using different radius and making a curved generic wall and then applying curtain wall type but the curtain wall always comes up completely straight.
This has only become an issue in the last few days. I have previously made curved curtain walls using the same curtain wall family in the same model.
4 REPLIES 4
constantin.stroescu
You have to apply Curtain Grids in order to make a curved Curtain Wall ( the panels a not curved)
Constantin Stroescu
josemukalel
Jose George
Architectural BIM/CAD Technician
josemukalel@gmail.com
+64 22513 0828
A KUDO is always welcomed; However, WHEN the above answer helps and/or clarifies your query; kindly mark it with ACCEPT AS SOLUTION
in reply to: josemukalel
Thanks for the quick help!
in reply to: constantin.stroescu
Thanks for the quick response - I don't know why but I thought curtain walls formed an arc with or without grids.. Thanks, this fixed the problem.
