Same look on section marks
Marcus.Isacsson
Message 1 of 16
Marcus.Isacsson
Hi fellas!
Is it somehow possible to get gaps for sections where the tails look the same?
Right now we've used the "gap" function that you manually have to change for each section.
Doesn't look good when they're not exactly the same in distance.
Replies (15)
Message 2 of 16
Sahay_R
Edit the section tail family.
In the family - move the geometry by the desired distance away from the intersection of the reference planes that define the origin of the family. Constrain and lock the dimension so that it stays constant.
That will fix the gap for every time the section tail is used.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 16
Marcus.Isacsson
Hi! Thanks for helping out, but I'm not quite sure I follow. Can you send a sample?
Message 4 of 16
Sahay_R
After you have followed the step in my previous post, follow the procedure in the attached screencast -
Rina Sahay
Message 5 of 16
Marcus.Isacsson
I'm still not sure I follow, maybe we missunderstand each other?
Here's a picture showing what I aim to get.
Right now we're doing it manually with "Gaps in segments" but maybe this can be done in a better way?
Message 6 of 16
Sahay_R
Can you share a file please?
Rina Sahay
Message 7 of 16
Marcus.Isacsson
Sure, here you go!
Revit 2018.
Message 8 of 16
Sahay_R
Try this. Let me know if it works for you and then I can explain.
Rina Sahay
Message 9 of 16
Marcus.Isacsson
I can't see what's changed?
Message 10 of 16
Sahay_R
I thought that you wanted a consistent gap in the section tails without any repetitive steps? Because that is what has been done in the family.
Rina Sahay
Message 11 of 16
Marcus.Isacsson
Are you sure that you uploaded the correct file? I couldn't find consistens gap in any of the section marks in the views.
Message 12 of 16
Sahay_R
Yup. This is the section tail from my file
The highlighted rectangle is the void object that I had added to the family to create the gap. If at all you need it to be larger or smaller, you would need to edit the family.
Rina Sahay
Message 13 of 16
Marcus.Isacsson
Alright, that wasn't the gap I was lookin for. I mean the line between the section tails.
Message 14 of 16
Sahay_R
Then move the void object in the family to give the required gap.
Rina Sahay
Message 15 of 16
whitbrs
Here's a short video I created that may help. Please let me know if it resolves what you are trying to do.
Simon Whitbread
Premium Account Support Specialist BIM, Revit
Message 16 of 16
Marcus.Isacsson
Thanks, I've used that solution. Got a problem when the section is split though. Know how to solve it?
