Room Tag Leaders
3 REPLIES 3
PhilvK
983 Views, 3 Replies
Room Tag Leaders
Even when I have “leader” checked for my room tags, when I try to move it out of the room, I still get the message that I am outside the room boundary and have to check “leader”. I then have to uncheck, then re-check “leader”, and then I am OK. What am I doing wrong please?
3 REPLIES 3
ennujozlagam
in reply to: PhilvK
hi, at the moment that is the only solution check and uncheck arrow leader as far as i know and there is no wrong with that. thanks
SteveKStafford
in reply to: PhilvK
You just need to be sure to move the tag by clicking on the "drag" icon (4-way arrow). If you move the whole tag then it isn't inside the room anymore, the leader's end need to be inside the room still.
My other older self here: http://forums.autodesk.com/t5/user/viewprofilepage/user-id/46056
PhilvK
in reply to: SteveKStafford
Perfect, thanks!
Forma Design Contest
Technology Administrators
