Room Tag Leaders
3 REPLIES 3
PhilvK
1030 Views, 3 Replies
Room Tag Leaders
Even when I have “leader” checked for my room tags, when I try to move it out of the room, I still get the message that I am outside the room boundary and have to check “leader”. I then have to uncheck, then re-check “leader”, and then I am OK. What am I doing wrong please?
3 REPLIES 3
ennujozlagam
in reply to: PhilvK
hi, at the moment that is the only solution check and uncheck arrow leader as far as i know and there is no wrong with that. thanks
SteveKStafford
in reply to: PhilvK
You just need to be sure to move the tag by clicking on the "drag" icon (4-way arrow). If you move the whole tag then it isn't inside the room anymore, the leader's end need to be inside the room still.
Steve Stafford
PhilvK
in reply to: SteveKStafford
Perfect, thanks!
