Even when I have “leader” checked for my room tags, when I try to move it out of the room, I still get the message that I am outside the room boundary and have to check “leader”. I then have to uncheck, then re-check “leader”, and then I am OK. What am I doing wrong please?
Solved by SteveKStafford. Go to Solution.
hi, at the moment that is the only solution check and uncheck arrow leader as far as i know and there is no wrong with that. thanks
Steve Stafford
