room colours not showing
46 REPLIES 46
Message 1 of 47
108527 Views, 46 Replies
Hi All, hoping someone can help. None of my room colours are showing up.
- I have assigned each room to a department
- visibility/graphics override, Rooms colour fill & interior fill turned on
Is it something in visibility or  type properties i have something wrong in, many thanks
46 REPLIES 46
Message 2 of 47
You need to assign a Color scheme that uses the Department as the criteria for different colors.
Message 3 of 47
Hello @Anonymous
Go to Annotate Tab > Color Fill Panel > Color Fill Legend and placed the legend on your working view.
To edit the Color Scheme
Select the Department Legend and click the Edit Scheme appeared in the Ribbon..
Message 4 of 47
in reply to: ToanDN
Thanks colour scheme is assigned to department, I can create the legend with correct names and colours but still colours don't appear in plan.
I don't have tag numbers set up but not associating colours to tags so not sure this is the problem, thanks
Message 5 of 47
in reply to: ToanDN
Attached is screen shot of colour scheme
Message 6 of 47
But did you assign the color scheme to the view?
Message 7 of 47
in reply to: ToanDN
Excuse my inexperience but how do I do that?
Message 8 of 47
Open the view and look at the Property palette for Color Scheme, click the box next to it and choose the scheme you have created.
Message 9 of 47
in reply to: ToanDN
Colour scheme chosen is one that is assigned called "planning presentation" (see attached) it reflects the chosen one in colour scheme?? Anything to do with materials?
Message 10 of 47
Is the floor surface pattern set to a solid color? As a test, turn off Floors category.
Message 11 of 47
in reply to: ToanDN
Turned off visibility of floors in model category, still nothing: smileyfrustrated:
Message 12 of 47
in reply to: ToanDN
see attached
Message 13 of 47
Can you share the Revit file?
Message 14 of 47
in reply to: ToanDN
Sure no problems , do I just attach it? Its a large file?
Message 15 of 47
Yes.
Message 16 of 47
in reply to: ToanDN
Trying to upload but its 108,000kb maybe too large
Message 17 of 47
Is there any other way for you to view, ie google drive or dropbox it just wont upload
Message 18 of 47
Any cloud solution works for me.
Message 19 of 47
in reply to: ToanDN
Great ill send the link now what address shall I use?
Message 20 of 47
 BIMadnessTN@gmail.com
If the project is not confidential, consider post the link here so others can provide feedback as well.  Up to you.
Forma Design Contest
