room colours not showing
Message 1 of 48
Hi All, hoping someone can help. None of my room colours are showing up.
- I have assigned each room to a department
- visibility/graphics override, Rooms colour fill & interior fill turned on
Is it something in visibility or  type properties i have something wrong in, many thanks
Replies (47)
Message 41 of 48
sgunnisHNAP9
None of these things fixed the issue for me. I tried everything but my room colours would not show.
I then realised that I'm applying the colour scheme to area plans, not floor plans. Room colours do not show on area plans. I now understand the singular purpose of a floor plan over an area plan though, which is nice.
I'm posting this in case there are other poor, unsuspecting victims of Revit's ongoing misanthropic mission out there.
Message 42 of 48
neevin.bilani
Community Visitor
Community Visitor
After trying everything I found the answer, you need to enter the Visibility/ Graphics Overrides and change the floor pattern to invisible foreground and background for plans and walls for elevation and then you can see the fill room color.
Message 43 of 48
sgozon
Observer
Observer
Make sure go to VG, under model categories, go to room then make sure your "color fill" is checked. See the snip for reference.
I hope this helps..
Message 44 of 48
sharanravich
Go to Visibility/Graphics in model categories - select Rooms drop down list and click colour fill and apply.
Message 45 of 48
Asmir
you need to define and pick Color Scheme in properties of view
Message 46 of 48
james.levieux
Hi everybody,
I was hoping to find a solution to my problem in this thread but unfortunately did not!  I've done hotel guestrooms this way many times but for some reason this model is not cooperating.
I use Spaces instead of Rooms since I'm working inside the architects linked model.  All of the guestroom are correctly reporting the room number from the architects model but for some reason about 5% of the guestrooms fail to display a color even though the are assigned the correct department.  I have the color in foreground and the floors are turned completely off.
You can see that rooms assigned to the same department will show both filled and unfilled.  If the floor isn't the problem, what else is there to check?
Message 47 of 48
NRutherford
Community Visitor
Community Visitor
 I just had the same problem and solved it by going into the view template, under V/G Overrides Model, and under the ROOMS tab (which was checked) somehow the "color fill" option was not checked. That fixed it.
Message 48 of 48
C2027242
Community Visitor
Community Visitor
I have a similar problem, where one of my rooms shows on the 1st floor but all on the ground floor.
