room colours not showing
47 ANTWORTEN 47
GELÖST
Nachricht 1 von 48
112010 Aufrufe, 47 Antworten
Hi All, hoping someone can help. None of my room colours are showing up.
- I have assigned each room to a department
- visibility/graphics override, Rooms colour fill & interior fill turned on
Is it something in visibility or  type properties i have something wrong in, many thanks
47 ANTWORTEN 47
Nachricht 2 von 48
als Antwort auf: Anonymous
You need to assign a Color scheme that uses the Department as the criteria for different colors.
Nachricht 3 von 48
Hello @Anonymous
Go to Annotate Tab > Color Fill Panel > Color Fill Legend and placed the legend on your working view.
To edit the Color Scheme
Select the Department Legend and click the Edit Scheme appeared in the Ribbon..
Nachricht 4 von 48
als Antwort auf: ToanDN
Thanks colour scheme is assigned to department, I can create the legend with correct names and colours but still colours don't appear in plan.
I don't have tag numbers set up but not associating colours to tags so not sure this is the problem, thanks
Nachricht 5 von 48
Attached is screen shot of colour scheme
Nachricht 6 von 48
But did you assign the color scheme to the view?
Nachricht 7 von 48
Excuse my inexperience but how do I do that?
Nachricht 8 von 48
Open the view and look at the Property palette for Color Scheme, click the box next to it and choose the scheme you have created.
Nachricht 9 von 48
Colour scheme chosen is one that is assigned called "planning presentation" (see attached) it reflects the chosen one in colour scheme?? Anything to do with materials?
Nachricht 10 von 48
Is the floor surface pattern set to a solid color? As a test, turn off Floors category.
Nachricht 11 von 48
Turned off visibility of floors in model category, still nothing: smileyfrustrated:
Nachricht 12 von 48
see attached
Nachricht 13 von 48
Can you share the Revit file?
Nachricht 14 von 48
Sure no problems , do I just attach it? Its a large file?
Nachricht 15 von 48
Yes.
Nachricht 16 von 48
Trying to upload but its 108,000kb maybe too large
Nachricht 17 von 48
Is there any other way for you to view, ie google drive or dropbox it just wont upload
Nachricht 18 von 48
Any cloud solution works for me.
Nachricht 19 von 48
Great ill send the link now what address shall I use?
Nachricht 20 von 48
 BIMadnessTN@gmail.com
If the project is not confidential, consider post the link here so others can provide feedback as well.  Up to you.
