Room Boundary issue
10 REPLIES 10
Message 1 of 11
Ramina_B
626 Views, 10 Replies
Room Boundary issue
I keep having this issue with room area/boundaries.
I have room bounded walls and curtain walls.
BUT the room area will only specify the area into the ''bay window'' sometimes.
I have attached a screenshot that shows how the area is ''bleeding'' into the curtain walls, as  I wish, but not doing the same thing on the left wall...
I have tried with ''cutt walls'', ''edit wall profile'' and both are not helping.
The actual method is edit wall profile.
10 REPLIES 10
Message 2 of 11
ennujozlagam
in reply to: Ramina_B
Have you tried a room separator to control the room area? Thanks
Message 3 of 11
Ramina_B
in reply to: ennujozlagam
The room seperator function is not letting me go out of the box. It can cut the ''bleeding''-part, but that is the opposite of what I need.  Thank you
Message 4 of 11
Avaris.
How did you draw the wall at the top of your drawing? Would it be possible you did draw that as separate walls?
Message 5 of 11
Ramina_B
in reply to: Avaris.
I don't have an issue with the wall on top, it's the wall on the left I need to behave as the one on top.
And I can't draw them seperately because it is mutiple levels which each different window holes.
Thank you 🙂
Message 6 of 11
Avaris.
Yes that is what I understand, question is: what did you do differently to the wall on the left?
Message 7 of 11
Ramina_B
That is exactly the mystery.
Nothing different, I did the same thing all around...
Message 8 of 11
You didn't by chance give your Level a Computational Height?
...Are you saying to you DO or DO NOT want the bays included in the room?
Message 9 of 11
Try Rectangular Wall Opening instead of Edit Profile see if it helps.
Message 10 of 11
Ramina_B
in reply to: barthbradley
I DO, want the bay window area to be included.
I tried changing the computation height, but that was when I was trying to solve the issue.
Message 11 of 11
Ramina_B
in reply to: ToanDN
I've been trying that aswell, it only helps sometimes, and sometimes it says ''no boundary'' to the tag.
Forma Design Contest
