I keep having this issue with room area/boundaries.
I have room bounded walls and curtain walls.
BUT the room area will only specify the area into the ''bay window'' sometimes.
I have attached a screenshot that shows how the area is ''bleeding'' into the curtain walls, as I wish, but not doing the same thing on the left wall...
I have tried with ''cutt walls'', ''edit wall profile'' and both are not helping.
The actual method is edit wall profile.
Have you tried a room separator to control the room area? Thanks
The room seperator function is not letting me go out of the box. It can cut the ''bleeding''-part, but that is the opposite of what I need. Thank you
How did you draw the wall at the top of your drawing? Would it be possible you did draw that as separate walls?
I don't have an issue with the wall on top, it's the wall on the left I need to behave as the one on top.
And I can't draw them seperately because it is mutiple levels which each different window holes.
Thank you 🙂
Yes that is what I understand, question is: what did you do differently to the wall on the left?
You didn't by chance give your Level a Computational Height?
...Are you saying to you DO or DO NOT want the bays included in the room?
I DO, want the bay window area to be included.
I tried changing the computation height, but that was when I was trying to solve the issue.
