I am an architectural student, designing a house. I changed the roof color using roof property, but it always shows black. Please help
Solved by barthbradley. Go to Solution.
Need more information. There is hardly enough there to make an intelligent guess. But if I had to guess at this point, I say the surface hatch pattern was soooo dense that it appears black at 1:1. Zoom in close and tight on a portion of the "black" roof. See anything more than black? Do you see hatch linework?
Thanks a lot for the suggestion. Still looks to be the problem, I am attaching the file here. Thanks again
